Need Tarbell Realtors Logo in Vector Format
Signs4Realtors
Need help getting vector Adobe Illustrator CS4 version of the Tarbell Realtors logo (see attached). I'm printing a Real Estate sign and customer is taking too long to get logo from broker. If anyone has the vector logo or can find the vector online, please let me know.
Thanks, David
info@951graffix.com
kroemer
That looks high res enough that you may be able to bump up the size a tad in Photoshop and live trace in Illustrator. Sorry I'm not providing the logo, I just think that may work in a pinch. Or pen tool it in Illustrator.
kroemer
See if this works for you - tried to upload a CS4 AI file but wouldn't let me. It's slightly rough but could be tweaked a tad to look official.
  • Tarbell.pdf
rossmosh
Inkscape is free and does an excellent job of vector tracing. Throw it in there and make a few test passes and you'll be good to go. At most, you'll need to manually insert the trademark symbol which is no big deal.
vid
PRO TIP:
n the Google search field type:
Tarbell's Realtors filetype:pdf
In looking at the results, it appears that the press release at ritalatham.com may have a workable logo --- I'm on mobile so I didn't download, but it holds together when one zooms in.
Import that page in to your vector software > release the mask, if any, and you should be good.
Fred Weiss
or use the auto trace, that's about as easy as it gets to convert
Easy and expedient for sure but not a delivery of the best solution possible. Extracting a authorized version from a PDF would be the best solution. An auto trace the worst. Auto trace produces an imitation of the original in varying qualities but always, like photocopying a photocopy, one step away from being garbage. Resetting the type, positioning it, welding the overlaps and drawing a line would take ten to fifteen minutes and would produce a high quality duplicate of the original.
