New 220 ml cartridge CMYKLcLm Triangle Mild Eco Solvent Ink
Discussion in 'Miscellaneous Printers' started by mysoljet, Oct 12, 2005.
  1. mysoljet
    mysoljet New Member
    1
    for Roland EX, VersaCamm, Mutoh Falcon Jr & Mimaki Printers
    • Quick drying time for production speed
    • scratch resistance for easy handling
    • Wider color gamut
    • Vibrant, brilliant colors
    • Color and Density consistency
    • Competitively priced
    • Aggressively adheres to a broad range of uncoated media
    • Profiles for Color Rip and Versawork
    • Only $49.95 each CMYKLcLm cartridge.
    Triangle Digital has done it again with the release of the latest entry into the world of Large Format Inkjet Inks. The new Mild Eco Solvent ink can be used on the Roland EX, Vesacamm, Mutoh and Mimaki Series inkjet printers. You will definitely enjoy the dramatic savings over OEM ink. Triangle ink’s track record has proven that the ink does not put your printer’s ink delivery system and heads at any higher a risk than if you use OEM ink. Printer maintenance is critical. You must perform the maintenance procedures as recommended by the manufacturer.
    For more information please call 626-961-7688 or www.nu-flex.com
  2. VinylCraft
    VinylCraft Active Member
    732
    :Sleeping:
  3. Derf
    Derf Very Active Member
    Thanks For the info! :Coffee:
