New Cintiq 24 HD Touch
Discussion in 'Computer Hardware' started by The Vector Doctor, Oct 11, 2012.
  1. The Vector Doctor
    The Vector Doctor Very Active Member
    3,366
    97
    48
    Aug 15, 2005
    Ohio
  2. WildWestDesigns
    WildWestDesigns Major Contributor
    5,370
    166
    63
    Sep 27, 2010
    Mid TN
    22" would be the way to go. I have a 21UX which just got replaced by the 22". Still pricey, but very much worth it. Embroidery digitizing is so much more efficient being able to work right on screen.
  3. rcook99
    rcook99 Very Active Member
    2,134
    3
    38
    May 25, 2006
    NE
    Ok I have a question for both. I was looking at the link you posted Eric and was wondering what is the difference between the Cintiq and the Intuos? It appears the one is a monitor and the later acts as a mouse pad but shows up on your screen. Is that the case?
  4. WildWestDesigns
    5,370
    166
    63
    Sep 27, 2010
    Mid TN
    The Cintiqs are pen input monitors. Although I think the 24 HD is also finger input, but I would have to look to make sure on that one.
    The Intuos are minus the monitor. Now you can have it act as a mouse or you can have the set to your monitor to where one specific point on the Intuos translates to one specific point on the monitor(s), so it would act more like the Cintiq.
  5. rcook99
    2,134
    3
    38
    May 25, 2006
    NE
    Mind you I had to pick myself up off the floor when I saw the price on the Cintiq's LMAO. Thanks for the break down.
  6. David Wright
    David Wright Active Member
    984
    9
    18
    Nov 25, 2003
    Wyandotte, Mi
  7. rjssigns
    rjssigns Major Contributor
    4,337
    228
    63
    Jun 4, 2007
    Home Office
  8. WildWestDesigns
    5,370
    166
    63
    Sep 27, 2010
    Mid TN
    I use a Samsung Slate, full OS that also has a Wacom digitizer in it. Smaller screen, but for a tablet it's not that bad. It is pressure sensitive, but no nearly to the degree as the Cintiqs are.
  9. David Wright
    984
    9
    18
    Nov 25, 2003
    Wyandotte, Mi
    Samsung slate looks good, we are going to be seeing a lot like that in the coming months with Windows 8.
  10. The Vector Doctor
    3,366
    97
    48
    Aug 15, 2005
    Ohio
    I need a big screen though. None of the slate/tablets are large enough.
  11. WildWestDesigns
    5,370
    166
    63
    Sep 27, 2010
    Mid TN
    I only use the slate for travel purposes, it's about as big as the 12WX Cintiq.
    Might want to try to find a 21UX on sale somewhere now that they are going to be phased out. Might be able to find a good one for a really good buy.
    David: The slate does have a Metro-like GUI as well. It's ok, but I sure don't like the idea of still having to deal with that type of interface on a desktop. I'm either going to hold off on 8 until they refine that or wait until the next OS that will hopefully either have just a mobile version or the ability to totally turn off the mobile interface depending on the application.
  12. CheapVehicleWrap
    CheapVehicleWrap Very Active Member
    3,943
    The 21ux is prefered by many over the newer one. You're not going to find one cheap, unless I part with mine and that's not happening. The price is worth it for many of you, especially you Doctor.
  13. MichaelAlmand
    MichaelAlmand Member
    293
    Sep 27, 2008
    Canada
    How do you like the screen with all the scratches? I had a bunch within the first month using a felt nib by the way. So I pulled of the non glare coating... then sold it. Going to get get the 24HD but I am trying to find out if they fixed the screen coating..
  14. WildWestDesigns
    5,370
    166
    63
    Sep 27, 2010
    Mid TN
    Don't have any scratches and I use the nibs that came with the pens (airbrush and regular pen). I'm going on two years with this particular Cintiq. It's possible that you got a bad one, or I lucked out and got a good one.
  15. CheapVehicleWrap
    3,943
    2 years, 5 pens. No scratches whatsoever.
