bob
...and what in the world is tangential?...
There are two methods currently in vogue with blade cutters; drag knife and tangential. Regardless of method, in order to cut media the cutting edge of the blade must always be facing the cut. When you slice a tomato, the cutting edge of your knife faces the cut. Likewise for cutting anything else, including vinyl, with an edged instrument.
A drag knife machine's operation depends entirely on having the tip of the cutting instrument not line up with the blades rotational axis. Referred to as 'offset'. When the cut changes direction the cutting edge of the blade will always be facing the cut for no other reason than this curious off-center geometry. The 'offset' is known to the plotter and the cutting path is nudged by this distance to produce precise cuts. This system works but the fidelity of the output pretty much is dependent on having the proper offset specified and having the blade completely free to rotate via the tiny bit of leverage offered by the offset. Hence the term 'drag knife'.
A tangential machine has exactly the same requirement that the cutting edge be facing the cut path but, rather than leverage gained by geometry, the machine has a mechanism for physically rotating the blade to a;ways be facing the proper direction. Cutting square corners is relatively simple but when cutting a curve, either an actual curve or a curve simulated with some number of faces, the blade must be turned such that is is exactly tangent to the curve it's cutting at every point along its path. Hence the term 'tangential'.
A tangential cutter is generally considered superior when cutting smaller objects. Objects less than ~.75" or so. For larger objects there is very little difference in output quality between the two techniques. The drag knife machine is simpler since it lacks the blade positioning mechanism which is more expensive and is something else than can break.
Thus endeth the lesson.
