You're trying to sell the idea that a sign maker can get by without RIP software for small to medium size large format work. If you don't have a real RIP program what else do you have other than a basic print dialog box? I don't know of anything in between. Or am I just to supposed to hand-code something together out of the blue?
Dear god, you choose the most extreme alternative. No, not at all. I'm just saying people shouldn't be totally dependent on what a 3rd party deems that they should have or not have. And not be afraid of extending what you have with your own tools.
There is little difference between someone that writes their own little script (or even program, be it cli or gui based (which is incredibly easier then I am willing to bet you think that it is, based on what you have said about Corel)) and the sign maker that creates their own "analog" tools (which there are some here that have done, I can mention one right off the bat that has said as such, but I don't want to call them out in case they don't want to be dragged into our conversation), but they do exist.
I don't understand why people get hung up creating and expanding their physical tools, but there is this mental block on software?
I'm not advocating having to come up with something totally from the ground up (unless you want to) extend what you already have. No reason not to build upon what others have done. But that would mean using open source, which is something that you seem to be against, so maybe there is really only to build from the ground up.
I'm not a software engineer, but it seems pretty obvious there is more going on under the hood with those operations than what someone could write in some simple macro.
Have you even tried? I tend to doubt it, but I could be wrong, I just don't think you have even given it a legit shot.
Also, if one is using programs that have a very open API to hook into, one is able to do a lot of wonderful things. Something that I don't think Adobe would have quite as open even if it was available. Hell, the ability to what you can or can't script via Actions is quite limited.
Look, if one want's to always be at the mercy of what others do (and their are legit reasons to just use commercial software) that's fine.
I just don't get a group of problem solvers doesn't want a little independence
and have tools that improve their workflow and give them a competitive edge (this was actually one of the pros that the above mentioned user is often quoted as saying).
it's great for scripting and learning Python.
Oh
nnnnoooooo!!!!!!!!!! A sign maker that's actually programming. Don't you know shoresigns that you as a sign maker aren't supposed to be doing that?
Is Mac still on Python 2.7 or have they finally at least moved to 3.6?
Also worth noting that I don't own an iPhone or any other Apple products besides my Macbook Air.
My wife had one of the 1st gen Airs, suffered from a kernel overheat that turned out to be quite common.
