Newbie from MI
Discussion in 'New Member Introductions' started by TC49010, Jan 19, 2005.
  1. TC49010
    TC49010 Active Member
    528
    Hello everyone!!
    I am new here, I found this group through a search for something!! I have been lurking since I signed up and looking through all the post. I just got a roland sx-15, getting all the supplies needed (I think ) !! I do embroidery and t-shirt printing and such now and wanted to expand. I have used my cutter a few times but now I have more questions!! I looked at the gallery of pictures on here trying to figure out what I can do and cant do with my cutter!
    I want to do Banners, decals, window lettering etc but still need to figure out what all I will need. Example: what do you use soapy water for? I have seen it in several post and am clueless!
    Thanks for letting me join your group, I look forward to learning alot!
  2. jpavlov
    jpavlov New Member
    18
    Welcome :Welcome: from Port Huron Michigan
  3. Dennis Raap
    Dennis Raap Active Member
    586
    Oct 5, 2003
    USA
    Welcome TC, soapy water is used to wet apply vinyl there are brand name products available for wet application such as Rapid Tac.
  4. Fred Weiss
    Fred Weiss Merchant Member
    20,920
    545
    113
    Sep 11, 2003
    Olympia, WA
    Hi TC and welcome to the forum.
    To expand on Dennis's reply ... there are two primary ways to apply vinyl lettering and graphics: wet or dry.
    Applying dry simply means the release liner is removed and the vinyl along with the protective transfer paper is squeegeed down. The pressure sensitive adhesive that comes on the vinyl has a greater strength than that which is on the transfer paper. Nearly full adhesion is the immediate effect. The transfer paper is then pulled off and the vinyl stays in place.
    With a wet application, a fluid (mostly water) is put in contact with the adhesive after the release liner has been removed. This is usually done by spraying it on the exposed adhesive and the surface being applied to. The effect is to temporarily reduce or eliminate the adhesive properties of both the vinyl's adhesive and that which is on the transfer paper. This allows a smooth, usually bubble and wrinkle free application ... again using a vinyl application squeegee. Depending on temperature, humidity and the type of substrate, the adhesive's bond soon redevelops and the transfer tape is then removed as with the dry application.
    Wet application is most useful for applying large graphics in one piece. Dry application is quicker and less messy and preferred for smaller graphics and by many more experienced installers.
    Hope that helps.
  5. Dennis Raap
    586
    Oct 5, 2003
    USA
    Well said as usual Fred.
  6. Sign Guy
    Sign Guy Member
    76
    Welcome aboard from Midland. There is a lot of expierence on this site and you will be able to get loads of info.
    Bob
  7. TC49010
    528
    :thankyou: for the welcome!!
  8. neato
    neato Very Active Member
    2,139
    284
    83
    May 16, 2003
    Henderson, IL
    Welcome from Spring Lake!
    Well, I'm in Iowa now, but I'll be back Michigan, I'll be back!
  9. dccas
    dccas Member
    234
    1
    Another welcome from MI, from the tip of the mitt
  10. TC49010
    528
    Thanks for the soapy water explanation!!! I have copied and pasted it into my growing stack of notes!! I appreciated all the help!!
    TC
  11. Rick
    Rick Certified Enneadecagon Designer
    6,955
    390
    83
    Apr 17, 2003
    Valle Vista
    Welcome TC!
  12. Grady
    Grady Member
    52
    Another hey from michigan. Grady
  13. TC49010
    528
    Wow nice too see several other michiganders!!! I dont feel so alone now!! Did the majority of you start off home based? How long does it take to get past the learning curve? Is there some place that I can look to see items that are generally used and for what? Like the soapy water and clear application transfer tape etc, I feel like I am sooo way in over my head!! :)
    TC
  14. Fred Weiss
    20,920
    545
    113
    Sep 11, 2003
    Olympia, WA
    There are several sign industry trade journals which are good for both the articles and the ads. I think Sign Business Magazine still has a free subscription offer.
    You'll find quite a few good supply resources in our Links section of Signs 101.
    I also suggest that you contact the sign supply distributors in your area and request a catalog.
    Once you are looking at specific items with descriptions and pictures, you should be able to form more specific questions and get better answers here.
  15. Grady
    Grady Member
    52
    I went to school for design and have worked in the business for the past seven years..If you have any questions i would be happy to help and the people in here are great...they rock man...
  16. bones
    bones New Member
    17
    welcome
    Hi Tc! Welcome from Lapeer Mi.
    Bones
