newbie here, problem with outline corel draw 12
Discussion in 'Corel' started by umbratint, Jan 29, 2006.
  1. umbratint
    umbratint New Member
    7
    Hi, how would I go about outlining text and then separating outline so it can be cut.
    Also would anybody know any books, links, or cd which would help me learn corel draw 12.
  2. Shovelhead
    Shovelhead Major Contributor
    10,882
    16
    Your "outline"....
    is called a "contour"......select contour from the effects dropdown....a dialog flout will open specifying how much countour you want.....then fron the "arrange" dropdown..."break apart"....this will give you a separate object.
    Also, if you add an outline...."create outline to object" will get you a similar result. You'll have to go to wireframe and delete the inline.
  3. umbratint
    7
    Got it thanx
  4. edwin
    edwin Member
    69
    http://www.ara.org/products/dsp_cat.cfm?prodcatID=13
    I have taken this mans class (acually twice) and have seen the video. He knows Corel Draw. This video is probably for version 11 (mabee 12 dont remember) unless he has updated, but I am sure you would learn plenty. If I remember correctly you watch a section (on your computer), pause then reinact what you just learned then continue.
  5. Cadmn
    Cadmn Very Active Member
    2,859
    Mastering coreldraw 12 is a cd out there
  6. Cadmn
    2,859
    book called Coreldraw WOW isn't bad
