massivewire
Hi All,
I am hoping one or two of you have some time to help me out.
I have got my hands on a Roland SP300v that had stood still with ink in for 5 years, over a couple of months I have replaced all serviceable parts, ink lines, soaked heads, replaced a blown fuse on the mainboard and beleive it or not I got the thing working, it prints and it cuts, that in itself is a miracle.
I have printed some stickers and cut them out using the cutline function in versaworks and all works well.
Anyway I have been reading and researching and found that I should be able to contour cut and also perferate the backing media.
I have plenty of experience with PCs and have a reasonable knowledge of Photoshop but Illustrator is something I have never needed to use. I have watched tutorial after tutorial to try to add the cutline in illustrator without succes. I have added the versaworks pallette in with the cut contour line but can not get it to work, when I open the PDF in versaworks it does not recognise a cut line.
I am wondering if anyone can explain it in a different way that may help me, once I get my head around the programme and how to create the lines hopefully I will be fine.
