JohnnyInfamous
I have a customer looking to get a large number of plastic interior hanging signs, about 3' x 4.5' with full color print on both sides. I don't want to use a corrugated plastic, as it just looks cheap (because it is) but I don't want to step all the way up to expanded PVC sheets. I'm confident that there's an array of plastic sheet products that could work here, I just don't use them often enough to know what to quote here. Usually when it comes to sign substrates, ACM and PVC are the cheapest materials I generally go to.
These would hang from the top two corners, so it should be a relatively rigid substrate, but not too heavy, and preferably can be printed onto both sides directly with a flatbed printer.
What materials would you all use in this circumstance? Thanks! -John
