nice banner poles....
nashvillesigns
they are 1.5" inches thick with round finials in black on the end. they come with a cast iron/steel plate that mounts on building...(the entire pole is black actually), and for the life of me, can't figure out who makes them..
:help:help:help
nashvillesigns
here ya go... any input is cool!
chris
SightLine
Keep in mind - if you are mounting them to a building you very much need to add an oversize plate to spread the load. Regular pole brackets are too small. When mounted directly to masonary/brick they WILL begin to move a small amount and get loose. Eventually they will fall - and sometimes take chuncks of brick/concrete with them. The mounting surface area is just too small. The one signpost-boston added a picture of has a proper plate to distribute the load.
I've personally gone and replaced regular ones mounted directly to walls by someone else for the Dept of Defense at a military base. They had only been up a year and all were coming loose. They used proper anchors and everything.... The military was very unhappy about it as one of them did hit someone when it finally came loose.
We replaced them with ones from Kalamazoo Banner Works. Used their airow poles with their wall plates. They prebuild them - very nice quality but not the cheapest.
dsmskyline
Something like those I would just make myself. 8"x8" plates and some 1" road with a steel ball on the end. Probably be less than $100 and a couple hours to make.
