Nissan NV Tall Van tips?
OADesign
Hi All!
We are doing a wrap on this Nissan NV Tall Van.
And we accepted the project before I got a chance to see all the details. (not that what I say make any difference lol)
Looks like this one is beyond my skill set and I am nervous.
Any tips on wrapping this van? What scares me the most is the deep recces on the sides. And access to the crown (with out damaging the hood or windshield).
Thanks in advance!
mudmedia
Use a ladder on each side of front wheel areas with a sliding aluminum scaffold over the hood to reach the panel above windshield.
Proper way to do channels on the NV is to cut them out if you search on the site you should see a few debates over right and wrong.
Good luck
MikePatterson
Head bathroom cleaner.
Plenty of Primer94. Try and get the material worked down into the recesses without stretching to much, then heat and work into the channels (aka don't bridge if you don't have to). I hate cutting into recesses, if you cut to hard you cut into the paint. Post heat set and you should be good to go.
SightLine
Do NOT use Primer 94 if you are using Oracal though. Also the trailing edge of the hood by the cowling is VERY sturdy, enough to handle at least 180lbs along it's edge. A scaffold to reach over the giant nose is probably a better method though. :Big Laugh
Good luck
tsgstl
I just did a partial on one of these (only the sides). I trimmed the recess, some don't I did and don't feel bad about it at all. Those lines are not straight so keep that in mind when laying it out. The sharp recess about a inch or two up from there is worse. And for some reason on the passenger side it is caulked. I never wrap over caulk so I had to trim that one out as well. All in All it wasn't that bad at all. Not as EZ as a box truck but similar to a van.
HulkSmash
Cut, and drop the channels. I don't care what anyone says it's going to fail. Even with 3m envision film. Maybe not immediately though
Kentucky Wraps
Kentucky Wraps
If you're light enough, take your shoes off and wrap the front top part with help. We did 2 of these full wraps...not bad. Cut and drop the recesses.
