Click to Support Signs101 ...
I bought an old Mutoh large format printer. When I turn it on it says "no capping position" Can anyone tell me what this means and how to fix this problem?
With machine OFF Hold down the Cleaning, Menu, & Shift Buttons all at the same time, while holding these buttons turn the machine ON You will hear a series of beeps from the machine, when you hear these beeps let off the buttons, and the control panel will say DIAG:EXAM Hit the menu button ONCE to DIAG:ADJUSTMENT Press the Media Button Once The print head will move around a little bit and then go back to rest position The control panel will say ADJ:HOME Hit the Media Button once, and the printhead will move around again and give you a negative number such as -63.xxx or -64.xxx for the 46", 48", and 62" and for the 38" Junior you will get a -72.xxx or -75.xxx number. Hit Media button once more and then shut the machine OFF and then turn the machine back on normally and follow the steps below for the powerful cleaning process.
Press the Menu button until you come to Menu: Utility Press the Media button Once Press the Menu Button to Clean: NORMAL Press the Resolution Button once to change NORMAL to POWERFUL Press the Media Button Once The machine will start the powerful cleaning process
