No cut-only option with this profile?
Colin
I just printed & laminated a small job (black ink on clear lam with clear laminate) and used the ESP-CL Clear PET film profile. I am now attempting to do the cutting, and the "cut only" option will not appear. I imagine that this is inherent with this particular profile, but is there a way I can make it work? Could I simply change the selected profile?
petepaz
Should be fine if you just change the material profile. You picked a profile for material that normally can't be cut.
Very important make sure you only change the material. Don't hit the material size button or it will screw up your alignment.
oksigns
I did this for pump toppers using Durasol film
Just like petepaz says. For me, I used a familiar vinyl profile in Versaworks that had the relative thickness to the film I was using, and I spent time calibrating the heat & cut settings. Be careful of the cut settings or else you might do as I did and wear down the protective cut strip with test cuts. It paid off in the end as I have the perfect cut settings moving forward that wont damage the blade and strip for future jobs.
