No ink is getting to the new printhead on my BN20
netsol
this can be very frustrating if it is your first time
i remember wanting to roll one of my printers out to the curb...
buy one of these
CAREFULLY pull each line off the damper and pull a vacuum. ink will come through
if it doesn't work put an empty or waste cartridge on the other end fill a syringe with isopropyl & shoot some into the cartridge
IF THAT DOESN'T HAPPEN, let each one soak for 20 minutes
if necessary put A LITTLE acetone in the alcohol solution
ONCE YOU CAN shoot alcohol into the cartridges, the vacuum pump WILL PULL INK
do each line one at a time, DO NOT CRACK THE MANIFOLD NIPPLES be very careful and gentle
take the pump line off the bottom of captop, hook up vacuum pump pull a vacuum.
it will pull ink INTO the dampers
this could take youa couple hours.
be careful and methodical
adamfromayr
Thanks netsol :) for your advice and those little connections on top of the heads are easily broken Im still working on it and will continue as wont to know everything about these BN20 and other printers
Im fitting the new media clamps! What a pain it is to fit these those awkward screws and the clamps bend so easily when installing them
I wonder the percentage of users who dont use media clamps?
Still working on the Blue and white inks blue is a bit clogged again
So important to have all teh connections tight the small brass bits with rubber o-rings as air in causes issues!
netsol
when it is printing, it will all be worth it.
i got my one roland in 2018 & it hasn't missed a day
adamfromayr
Spoke to soon
I had new issues with the Scan motor Pinch rollers i installed new media clamps and used white foam tape i changed it too black tape and the pinch roller has went away!
NOW im almost out of ink and its all moving freely again left to right
but
GUESS WHAT?
No ink coming out printhead again
BE STRONG ADAM You will get there!
netsol
i wish my mutoh had media clamps, instead of the takeup reel
