No M ink
signgal01
I ran out of M ink on Monday and had some shipping problems getting a new cartridge in, maybe ran one cleaning between Monday and Today. I am not getting any red out of my machine (Mutoh Falcon Jr) today. I have ran powerful cleanings, let the heads sit on the sponges with alcohol, and don't know what else to try?
signgal01
Thanks, I did pull red through the line and did a ridiculous amount of powerful cleanings and got it to work.
Now I'm having other issues. All my colors look good after a cleaning and a nozzle check and then about 1-2 feet into a print job one of the colors will just stop printing? I think I have either air in the lines or my husband thinks maybe a head problem?
thmooch
You might want to pull the cover & check the line in question for a crack, letting in air. Mine had 2 cracked lines when the carriage traveled all the way to the left they bent at the crack & allowed air in the lines.
Might not be your issue, but could be.
Ghost Prophet
Can you provide a photo by chance? Only thing I can think of right now since you recently replaced the cartridge and pulled ink through the damper is that you could have offset or damaged that damper o-ring.
Hope you don't have other problems with that new ink....
+1
tcorn1965
We are with magenta. If we quit printing for a while we have to do a nozzle check to get back. Our rep says it is a known issue and is sending us new. Something about a bad batch or batch #? Not really sure. Running a Mutoh RJ-900
Terry
signgal01
Thanks, my red ink is working great, but now my yellow isn't working. I do cleanings run and nozzle check and every thing looks great, then I start printing and the yellow disappears.
I have been having this same issue on and off all summer with all the colors except the black. I will put a new cartridge in and things will start working about after a lot of cleaning and sometimes pulling the ink through the lines. For some reason when the cartridges get low I have lots of problems and am going through ink like crazy. I've had this machine for over 4 years and haven't had any problems until this summer.
I'm beginning to think that it is either the lines or the cartridges? any ideas?
randya
Terry
Are you running this as a CAD printer or dye sub?
Wraps ink
sounds like mutoh's ink claimed another victim...good luck with that one...dont go buying a bunch of parts before you research the whole mutoh ink switcharoo. I had two printers doing the same thing and everyone said it was air in the lines dampers maint. stations...and I started using different ink and all the problems mostly went away
signgal01
where do you get Valuejet inks? I cleaned my wiper and got the new mutoh inks in the printer and my printer has been working perfectly for 3 days now? I can tell that the new mutoh ink cartridges (that are transparent) fit into the printer tighter, like they use to.
