No the dampers themselves. You're putting black ink through the cyan channel and cyan through the black channel.so try swapping the ribbon cables between black and cyan?
Its always a possibility but rare for a single channel to be damaged electronically. If you do the damper swap it will isolate where the problem is.a while back the fuse for the black/cyan head went out and we had it replaced is it possible theres another fault electronically?
is it possible a page file is set incorrectly again, we just had to reset the machine via page file. the machine thought it was a sp-300vs model and wouldnt recognize any of the Ecosol inks
fuses are good theres one for each head and that was the first thing i checkedi had a very similar effect when i bought my sc545-ex
the problem went way when we changed the black head
it had a blown head fuse when we bought it
