Nozzle wash results
chartle
Here are my results of a test draw on my JV33-130
The bottom shows what it look like before a nozzle wash the top after.
First I know there is one drop out marked with a green rectangle also ignore some of the other blemishes which are from I guess dirty rollers parked on the material. Also all the bars look the same its just the scanner I used.
Its the purple area that I'm wondering about on the bottom (pre wash) the black seems to encroach into the yellow nozzle area. After a 5 min wash( above test) its almost gone. Wondering what it could be and if its a problem how much its going to cost and is it worth it on a 7 year old semi lightly used machine.
ETA: I hope you can see the issue.
Alan Menhennet
Hi, it looks like it could be your wiper that is not lined up correctly with the head... Or problems with your capping station. Neither expensive to fix
chartle
Well I just did replace my capping station after never being told I should be. And also replaced and continue to replace and clean the wiper. For the wiper I take one off after a time and switch it with one thats I soak in cleaner.
Oh so I don't need a head change and therefore can't make a case to get a new printer. :cool:
Alan Menhennet
Just make sure that your wiper is lined up with the head, meaning that when it wipes accross the head it doesnt miss a part of the head
