Hello there!
I've had a Mimaki CJV150 for about 20 months now and lately I'm having issues with the head nozzles, and it got worse in the last month (see attached test print please).
Mimaki technician came to check this and he only replaced the wiper. According to him (and to the tests he did), there's no need to replace the cap (it's never been replaced by the way) because it's sealing properly (so he says). I always do all the routine maintenance and cleaning, already tried the head cleaning functions a couple of times (normal/hard/ultra), fill up ink, and did a 5 hour nozzle wash with no improvement in the results. I only use Mimaki original mild solvent ink, original wiper and stuff. Tech said there's nothing that could be done to improve it neither to stop it from getting worse, that I'll need a new head soon and this is probably happening due to low use.
I don't wanna try the syringe process because I can't afford another printhead right now if something goes wrong, but I do believe there must be something I can do to prevent other nozzles from clogging. As you can see, the problem seems to be very specific with magenta lines. Tech guy said that if the capping wasn't sealing properly, nozzle clog would be in all other colors too.
I print few stuff, like one hour a day. And no parts were replaced yet (except wiper).
What do you guys think? Is it good idea to do overnight soak every day from now on, to avoid more clogging? Do you think changing the cap may stop worsening this issue?
Thanks in advance and greetings from Brazil!
