Odd substrate request
megacab
I have a request for a substrate that I am having a tough time searching for. I don't even know if it exists, but the customer wants it. What i need is some kind of rigid, fairly thin, printable and contour cuttable on like a flatbed that has like a fabric texture/feel on one or both sides. basically it is for something that can have absolutely no shine, not even in full sun applications. it needs to be somewhat durable. any ideas? i have tried using like a matte lam, both liquid and roll, and no luck. still shiny on things like coro and styrene. I am stuck and need help if anyone has crossed this bridge before. thanks in advance for any help given.
Randy
2B
how rigid are you referring to?
MDO board or 040 aluminum?
1st though is styrene
2nd though foam board
both come in the "matte" finish
10sacer
Print to Phototex and mount to whatever thickness of styrene you want then cut out. Or premount to the styrene and print as one large sheet and then cut out. Either way.
megacab
Nope, you didn't miss anything.... I did. I didn't see rigid. :covereyes:
No biggie Gino. I was googling Dull Nylon like a MOFO yesterday and not coming up with anything:frustrated: thought it was me:ROFLMAO:
for the other questions, i am needing something about as thick as 4mil coro and suitable for exterior use.
megacab
that may be how i have to handle it.
thank you sir and thanks to Tammie and 2B for the suggestions also.
You can get nylon banners and they're rather very dull in color/sheen regardless of the color you choose. Some vinyls stick to it and then... there is some specialty vinyl designed just for it, but you need rigid, so forget it.
