Oiling the slider bar - JV3
speedmedia
Tried to do a search for this but I didn't have any luck. I was probably typing on the wrong terminology.
Anyways, I am needing to oil the bearing where the carriage slides on the bars on my printer. Anyone using anything with good results beside the overpriced Mimaki lube? I didn't know if there was a general purpose lubricant that would work for this or not.
Any help appreciated!
Thanks,
Kurt
CL Graphics
i use 3 in one oil. wipe the bar off with a rag, put a little oil on a swab and rub it on the bar. I also use 3 in 1 for the slider bars on the wiper and the slot the wiper slide into. Keeps the wiper from getting stuck if it gets ink down there.
gabagoo
I run alcohol once a week to clean the bars then use 3 in 1 to oil them back up. Can really feel a difference when you move the head for a cleaning.
CL Graphics
I usually dont move the head. Just clean and oil while cleaning the wiper. When the head goes back to the capping station i do where the head was when it was out.
GB2
Old Member
If you are interested, the correct product for this is:
Mimaki SPC-0364 Y Axis Lubricant
Though I know 3 in 1 Oil is a common tactic, personally I would just get a one time, lifetime supply of the correct product, the cost in that respect is nominal.
