OKI (Seiko) ColorPainter M-64 Error 2614
Discussion in 'General Signmaking Topics' started by ToneCustomSigns, Jun 30, 2020.
  1. ToneCustomSigns
    ToneCustomSigns New Member
    2
    Jun 3, 2019
    San Antonio, TX
    Has anyone encountered Error Code 2614 on their Oki (Seiko) ColorPainter M-64s? It happened after I did a tank refill and now I can't get the error to clear. I'm sure it has something to do with a sensor but how convenient that the book does not include a list of error codes and how to clear them.
  2. C5 Service&Repair
    C5 Service&Repair Member
    318
    39
    28
    Jan 14, 2018
    Omaha, NE
    2614 is the subtank full sensor error on color 5. Restart the machine and reinstall the cartridge.
    I've seen it happen that the subtank gets too full and the pump can't correct it so you'll get stuck on this error. I'ts a barrel of monkeys to get it to correct itself.
  3. ToneCustomSigns
    2
    Jun 3, 2019
    San Antonio, TX
    Thank you!!
  4. L.D
    L.D Member
    115
    13
    18
    Jan 19, 2018
    Atlanta
    If you put CP manager in service mode you can use the Actuator menu in order to run ink back to the cartridge. This will Lower the ink level in the subtank and remove the error code.
    It may be time to replace or cap and pump on that channel. Ink doesn’t appear to be pulling as it should.
