Old Omega can't read new Omega??
Discussion in 'Gerber Omega, Graphix Advantage & MacImprint' started by Kell, Jun 18, 2005.
  1. Kell
    Kell Member
    74
    Another one for the Omega users!!
    I've designed a sign on a brand new version of Omega...I take it to our shop to cut it out the next day and when I try to open it I get a "File written by newer version of Omega, file not readable" message!
    We upgraded our shop version from Graphix Advantage a couple of years ago but one would think that it should be able to handle the new files!
    Do I have to resave the original file as something else and import it??
    Seems odd.
  2. Marekdlux
    Marekdlux Member
    50
    The old omega can't read anything saved in the new version. There is an option to "save as" plt 1.56 version.
    -Marek
  3. Kell
    Kell Member
    74
    Excellent...thanks very much I'll give that a try.
  4. Fred Weiss
    Fred Weiss Merchant Member
    20,920
    545
    113
    Sep 11, 2003
    Olympia, WA
    Pretty much any software you get will have this issue. Files are generally backward compatible but not forward.
    I have two seats of Omega. One was updated to 2.1 and the other is still running 2.0.2. I haven't upgraded it yet (it's a free upgrade) because I wanted to insure that there were no bugs that might cause a problem. The version 2.0.2. won't open the files saved from 2.1.
  5. Kell
    Kell Member
    74
    Thanks a lot guys, the things you learn here!!
    I saved it as a 6.2 and it worked perfectly...thanks again guys.
