Omega 2.5 Edge2 and HS15plus run on Linux ?
Discussion in 'Gerber Omega, Graphix Advantage & MacImprint' started by Me again, Sep 14, 2020.
  1. Me again
    Me again New Member
    5
    Oct 2, 2012
    Qld. Australia
    Hi all, me again.
    So my XP computer has died which I've been running Omega 2.5 Edge2 and HS15+ on for years.
    My laptop has been running subscription flexi and a HP L360 & Summacut on Win7.
    It would be nice to bring the 2 systems together onto a new machine - so automatically Win10 comes into view. However, Omega 2.5 isn't going to run on Win 10 and I'm not keen on upgrading it to Omega6 for no real benefit as I only use it for a handful of customers.
    Looking for suggestions or similar real life setups.
    Or thinking outside the square, will the Gerber gear work on a Linux OS such as Ubuntu ?
  2. netsol
    netsol Active Member
    750
    103
    43
    Apr 26, 2016
    englishtown, nj
    i believe you can virtualize an instance of xp & run the old omega on vmware payer
  3. Attila Nagy
    Attila Nagy New Member
    18
    1
    3
    Sep 24, 2018
    London
    Omega2.5 with Edge2 never going to work on Linux. You can use it on Windows10 as long as it is 32bit
    For Edge2 printing, only one kind of USB adapter supported(impossible to find) The cable Spandex currently selling for Edge2 is not the one. Better make sure you have ECP printer adapter.
    Automatic multi mode or PCIe parallel cards are not supported
  4. netsol
    750
    103
    43
    Apr 26, 2016
    englishtown, nj
    if you virtualize an instance of xp, you can use a inexpensive parallel port print server.
    https://www.amazon.com/StarTech-com...4&sr=1-1-f6b8d51f-2c55-4dc3-89ad-0c3639671b2d
    if you watch ebay you can get a digi anywhere usb device and connect any usb device to your vm, without the pesky usb mapping everyone uses
    i use the digi devices for commercial clients for software they say can't be virtualized. the device is so stable we schedule reboots twice a year
  5. Attila Nagy
    18
    1
    3
    Sep 24, 2018
    London
    Gerber Omega 2.5 does not send Edge2 jobs to network or virtual printer port. It only works with native PCI or ISA bus ECP printer port. Or one type only USB print adapter.
