Need Help Omega 4.0 color palette not visible?
Discussion in 'Gerber Omega, Graphix Advantage & MacImprint' started by dexproduktion, Aug 5, 2020.
  1. dexproduktion
    dexproduktion New Member
    3
    Aug 4, 2020
    Hudiksvall
    Hi.
    Im running Omega 4.0 with our Sabre 408 but recently picked up a Gerber EDGE I for very cheap.
    I do have knowledge with EDGE's as I worked with one for almost 10 years earlier on.
    I just can't seem to change foils in the artwork at all, the palette is missing inside the software.
    It's installed and visible in "GSP Palette Manager" but not visible inside Composer, also it's greyed out in the "view" menu. Any advice would be apreciated, this is starting to drive me crazy as ive spent 5 hours troubleshooting already.
  2. Fred Weiss
    Fred Weiss Merchant Member
    20,552
    411
    83
    Sep 11, 2003
    Olympia, WA
    I'm wondering if the version of Omega you're using is a limited version that doesn't have permissions for Edge printing.
    • Agree Agree x 1
  3. dexproduktion
    3
    Aug 4, 2020
    Hudiksvall
    I don't really think so, i've tried the 4.0.0.52 Lite from the website as well as an older "full" one 4.0.0.38. The dongle just says Omega 4.
  4. Joe House
    Joe House Active Member
    951
    211
    43
    Feb 5, 2004
    WA
    Omega keys came in basically 4 flavors. One only lets you output - Plot Station, One lets you design only - Layout Station, One is for cut vinyl only and also lets you output to plotters - CS for Cut Solution or Cut Station and CP - Cut/Print. If you don't have CP or LS, you can't make changes to foil colors. These are different than the version that you have - 4.0 vs 6.5 vs ???.
    If you right click on the Gerber Tray Icon down by the clock and select "System Identification String" you should be able to see if it says "EDGE Ready" or not in the options box.
    Good Luck
    • Like Like x 1
  5. dexproduktion
    3
    Aug 4, 2020
    Hudiksvall
    Thanks! Now it's all clear. Even the dongle says 4.0 CS on the side.. :(
    Is there any way to upgrade to CP version?
    I mean, going 6.5 CP full upgrade seems a bit pointless with an old EDGE 1 printer.
  6. signage
    signage Major Contributor
    9,517
    75
    48
    Oct 5, 2005
    Penn
    Other than find a used version for sale, no.
