Omega "to back" - "to front" etc.
Discussion in 'Gerber Omega, Graphix Advantage & MacImprint' started by Kell, Jun 10, 2005.
  1. Kell
    Kell Member
    74
    This one is for the Omega users...
    I'm having a heck of a time with the Omega "to front" - "to back" commands.
    Say I have two overlapping squares, when I highlight one of them and hit the to back command (or whichever layer is appropriate) I get a screen flicker but no change in their position. This also happens if I hit the "back one layer" or "ahead one layer" buttons.
    I've read the pertinent sections of the user's manual but all I can find is a description of what the buttons are supposed to do.
    I know I'm missing a step here somewhere...could anyone help me out?
  2. quicksignguy
    quicksignguy Member
    31
    Kell, I use Omega composer as well. I use the keyboard shortcut "ctrl + Page Up" (or Page Down) as required. It works fine for me. Can't suggest anything else. I never use back 1 or front 1.
    Dave
  3. Fred Weiss
    Fred Weiss Merchant Member
    20,920
    545
    113
    Sep 11, 2003
    Olympia, WA
    Are you setting up just vinyl or Edge prints? If you are just in Vinyl Only view then they don't work and you must change your layer order in the 1234 dialogue. Try switching your view to Print order - Output and try it again.
  4. Kell
    Kell Member
    74
    Quicksignguy, thanks for the response, I appreciate your willingness to help with this.
    Fred, I changed the print order in in View and it works like a charm...thanks a million!
