One-Way Vision Perf
Bannerday
Anyone have any experience with One-Way Vision product. They claim you can clearly see out with it. That true?
Has anyone tried it with latex ink?
Thanks.
wildside
looks like a tinted window from the inside almost, use it all the time
laminate it, safer that way if it is on a vehicle
wildside
it would depend on the building itself
when it rains, the water will "pool" inside every little hole, which creates a clouded or blurry effect when looking out, plus dirt will collect in the holes, but a good rain washes it out and back to normal
i pretty much tend to laminate every window perf job, just my standard way, others will say not too, up to you and what you feel comfortable with though
BigfishDM
Are you refferring to one way window perf correct? You can see out of it no problem and my version works great in latex also. Most people dont laminate it but really depends on the way you intend on using it as water can pool up in the holes.
Speedsterbeast
I would not and do not laminate it.
Just don't expect more than a couple years out of it.
But yes, you can see fine out of it- when it's dry.
