CanuckSigns
I've run across a bit of a unique problem with our summa f1612. When we are using the router to cut out thicker black substrates (black pvc, 6mm ACM etc) the camera will often mistake the end point of a segment as a crop mark, which makes sense since it looks like a 5mm black circle and it's right beside the actual crop mark.
The 1612 has the option to read Square crop marks, however I don't see it as an option in onyx 12.2, I know I can use the plug in to generate the marks, but it's much better for my workflow to have onyx handle the nesting and print the cropmarks and barcode.
Is square crop marks an option for the F series in newer versions of onyx? Does anyone else have a work around? Would selecting a summa roll cutter with square marks be an option to then cut on the 1612?
Cheers!
Cheers!
