Goatshaver
Shaving goats and eating bushes
I've been struggling with cutting techniques and one thing I'm having trouble with is Onyx cut server. Now I want to do a Contour Cut and then a Flex Cut in one pass. (Not sure this is possible) In any case if I layer my file with Flex Cut on bottom and Contour Cut on top when I print it to the cut server it only shows one layer. Now here's something I thought was odd I had a test sheet with different cut shapes on it. One was setup with just a contour cut the others had two layers. Top was contour cut and the bottom was a Flex Cut. Now as it gets imported into the cut server only one layer is shown, but when I start the cutting it did 2 contour cut passes automatically. Thinking I had replot on I checked and nothing was set to replot.
Now it appears onyx will just shove both recognized cut layers into one and you wouldn't even know it, as there is no way to separate them once they are in Onyx Cut Server.
I cannot figure out way to do these in one pass. Only two separate passes of cutting the entire sheet.
