Onyx 7 Add Image Problem
Discussion in 'RIP Software & Color Management' started by HaroldDesign, May 12, 2011.
  1. HaroldDesign
    HaroldDesign Very Active Member
    1,367
    When using the ProductionHouse layout I suddenly can not add an image. Clicking on "add image" or right clicking in the preview window and selecting "add image" both do nothing. I tried re-starting, etc... and nothing. Has anyone else had this happen?
  2. HaroldDesign
    1,367
    Re-Installed after uninstalling several times. Run-time error. Ugh...
  3. HaroldDesign
    1,367
    Run-time error during install. Sorry for the re-post.
  4. HaroldDesign
    1,367
    I'm up and running after re-installing 7.3.2. However, Layout will open an .eps or .pdf, but it won't actually show in the preview - as if there's nothing there. A .jpg shows fine, but not any files I actually need to open. I'm able to rip in pre-flight to keep things going, but I really need Layout to work correctly. Any ideas?...
  5. HaroldDesign
    1,367
    :banghead: :frustrated: :banghead: :frustrated: :banghead: :frustrated: :banghead: :frustrated: :banghead: :frustrated: :banghead: :frustrated: :banghead:
  6. signswi
    signswi Very Active Member
    2,136
    2
    We never use Layout so I can't help there, but I just had our Onyx RIP hard lock and corrupt our printer cfg files. Deleting the printer from Onyx to reinstall deleted all the archived work & cut files, so now I'm running a deleted files recovery on the HD that's going to take ~8 hours.
    Yay. :frustrated:
  7. blueboyan
    blueboyan New Member
    1
    Remove Settings
    Go to the onyx folder and remove the settings folder from in there. If you are scared to delete it, you can just change the name. This fixed the issue for me.
