Onyx Colour Replacement Using Spectrophotometer
jasonx
Is it possible to use the eye color selector tool and replace that colour with a measurement from the spectrophotometer (X-Rite Eye One)? Or can I only use CMYK values?
Bly
I'm not sure I understand the question.
You can measure a colour sample with a device in RipQueue:
Setup > Postscript > Color Matching table > User defined colors
jasonx
I've got a raster artwork file and I'd like to use the color selector tool and replace a color with another color that's from the spectrophotometer. The color replacement tool only lets me specify CMYK values as the replacement color.
JWesthead
You could get the CMYK value and plug it in if you had a measuring program...like ProfileMaker Measure Tool. I dont know what other ones are out there.
JWesthead
Actually I think you would have to create a spot color because I wouldnt trust two different programs interpreting CMYK values the same.
JWesthead
Actually in ProductionHouse if you go through Setup/Postscript/ColorMatchingTable then go to User Defined Tab and Add, theres an area you can use a spectraphotometer and will measure out an LAB value ..... from there whatever you name it create a spot color with that EXACT name in Illustrator and the RIP will the recognize it and make the proper adjustments to achieve it.
As others have said, the User Defined Tab of the Spot Color Matching Table, and define as a spot color with LAB values behind it. Then create a spot color of the same name in Illustrator (or your vector app of choice), and you are good to go.
