hello!
i have some small badges to print and cut. So i set up small page sizes - 1340x500mm, so that cutcountour could be more precise with cutting. And when i insert number of copies, lets say 1000, i get 5 separate pages size 1340x500mm. Now im having problems with distance between pages. Printer automaticaly set it to 10mm. I would need at least 60mm.
Can i set, that contour square would be 60mm (30mm on every side) smaller than page? Because i don like that square is few mm from the edge. Now i have page sizes set to smaller than actual, but if i set align to center, it actualy isnt in center.
And i have another problems with contour cutting. With larger pages, for vans, around 2000mm length. Im (well, cutter is) having some problems with reading contour lines. And these problems are random.
First scenario: It gets to read the code, and i get error, that code is to small - but it is the same as on other side which is read fine.
Second sc: It reads code ok, left and right corner, then it travels up, and it should read that point in the middle, little black square, but it gets bye, and keep rolling... until media falls out, and i get error with media feed.
Third sc: It reads code ok, left and right corner, then it travels up, read that right middle point, and then travels left, to read left one, but it moves a little bit up, so that it doesnt find that left point. I get error for contour lines.
I dont have any possible idea what could be wrong. Is it a software or hardware issue.... i dont know. If i turn page, and try sometimes it works, or i get second scenario or third....
