Onyx Thrive and Colex Marks
mbasch
We are attempting to stream line our workflow and use Thrive to generate the cut file for our Colex. It does, but it adds a ton of extra marks we don't need. We only want to have 3-4 per board. Does anyone know if there is a way to change how many marks Thrive adds to the board? Is there a config file we can hack?
C_support
You can change the spacing for the reg. marks placing or you can set the Optiscout to read less marks.
MGB_LE
Is there any documentation to guide the optimizing of Colex and Onys working together? I overhear our Colex cutting out 25 graphics one at a time because prepress added dots for a 1-up print and my wide format operators nested and printed multiples of the file.
C_support
If you have 1 file printed with the "step and repeat" feature you can activate this feature at output to device. The software will read all copies and cut everything in one shot.
MGB_LE
Where would I find that option? My Sharpcut is from 2015 and I have CCC8 installed.
