Opening eps files with Corel 12???
Discussion in 'Corel' started by Slack11, Dec 16, 2005.
  1. Slack11
    Slack11 Member
    120
    I can't open eps files in corel draw. When I try to import them, all that is imported is a gray square with the name of the file I tried to open. Is there a trick to doing this? Within the help section it says I should be able to open these.
    Any help would be appreciated.
  2. Cadmn
    Cadmn Very Active Member
    2,859
    You need to make sure you installed the correct filters for import of those files I have no problem
  3. graphix
    graphix Member
    404
    Dec 15, 2005
    Ohio
    sometimes in at the bottom of your import box when it pops up you see..Files of type....select ps,prn,eps,-postscript-interpeter..and that might work or try to just open them with the same settings as above..sometimes it works for me...
  4. Fred Weiss
    Fred Weiss Merchant Member
    20,471
    368
    83
    Sep 11, 2003
    Olympia, WA
    You are probably using the "All Files" setting for "Files of Type" when you are importing which then has Corel choosing the import filter. As mentioned there is a specific filter set named PostScript Interpreted which can be selected. There is also a second filter named Illustrator AI - EPS which, IMHO, works better than the PS Interpreted. Try selecting each and compare the results.
  5. The Big Squeegee
    The Big Squeegee Major Contributor
    Opening eps files in CorelDraw
    Try using "open" instead of "import"
    I get files like that from a customer quite often:thumb:
  6. Slack11
    Slack11 Member
    120
    Thank you guys for the help.... I switched the type of file and it allowed me to open these. The open command worked also. Man, it is nice to have this forum to ask questions about this stuff.
    Thanks for all your help.
  7. Fred Weiss
    20,471
    368
    83
    Sep 11, 2003
    Olympia, WA
    The only difference between Open and Import is that the Open command creates a new page and the Import command brings the file into an already open page. There should be no difference in how well or poorly the selected import filter works.
  8. The Big Squeegee
    I have recieved some .eps files that will not import no matter what import filter is used. You can open these files and then copy and paste into the file you want it in. An extra step but one that is nice to know about.
