Oracal 210 lam problem?
Discussion in 'General Signmaking Topics' started by Desert_Signs, Jun 14, 2012.
  1. Desert_Signs
    Desert_Signs Active Member
    653
    2
    We've been using 210 for a long time, and recently we've had an issue crop up. We use a Seal laminator. When we load the lam on the top roller (the tension roller), the lam just spins on the core. It seems Oracal has stopped attaching the lam to the core. This is a huge pain in the ***.
    Anyone else noticed this or did I just get a couple bad rolls? It's easy for me to fix (I just attach it to a new core and wind it on to it.) But, I shouldn't have to do that.
  2. Jack Knight1979
    Jack Knight1979 Very Active Member
    1,091
    2
    38
    Jan 23, 2008
    Maine
    I had some a couple rolls ago where the release paper was fused on the edges of the roll. When you're laminate the release paper would tear and cause all kinds of hell.
  3. Mosh
    Mosh Major Contributor
    5,809
    41
    48
    Oct 19, 2009
    Nerbaska
    Do you have alot of humidity in your shop? We have problems in the time of year when it is getting warm but not hot enough for the air cond but is warm and humid, thus is super humid in the shop. Once we are running the air cond full on NO problems. I do know 210 's backing is thinner than the 290 and does need some adusting.
  4. Desert_Signs
    653
    2
    It's dry. Probably a little too dry. This is the first time in years that it's happened. I almost wonder if it's old stock. We have received a couple rolls of lam with, what I presume, is a new backer (no more grid squares). Those are fine.
  5. Graphics2u
    Graphics2u Very Active Member
    1,839
    2
    38
    Jan 31, 2007
    Iowa
    I would think that's just a couple rolls that were messed up. I can't imagine them not attaching the lam to the core.
  6. Intense01
    Intense01 Member
    109
    Just got 2 new rolls in today in matte finish and they were both not attached at the core.....
  7. Desert_Signs
    653
    2
    Good to know it's not just me. I'll call my supplier.
