Oracal 651, Work as Dry Erase?
Discussion in 'Tips & Tricks' started by cptcorn, Nov 3, 2009.
  1. cptcorn
    cptcorn adad
    1,210
    2
    36
    Jul 16, 2007
    Two Harbors
    I've heard this rumor does it work?
  2. Mosh
    Mosh Major Contributor
    5,809
    41
    48
    Oct 19, 2009
    Nerbaska
    Nope, red strains it. Get some dry erase overlaminate, it works great. Fellars has it.
  3. cptcorn
    cptcorn adad
    1,210
    2
    36
    Jul 16, 2007
    Two Harbors
    I'm currently using Kapco material now. My plotter doesn't like to track it straight, everything else goes through, which is extremely odd.
  4. ProWraps
    ProWraps Very Active Member
    3,556
    Sep 30, 2009
    San Francisco, CA
    probably the backer. might be slicker than normal, or thicker than normal.
  5. insignia
    insignia Very Active Member
    It'll stain from the markers, as will most non-dry-erase vinyls.
  6. MachServTech
    MachServTech Very Active Member
    1,220
    5
    38
    Sep 19, 2008
    North Carolina
    yes the Kapco does that for me as well.
  7. RebeckaR
    RebeckaR Active Member
    756
    3
    18
    Mar 7, 2008
    utah
    We've been experimenting with the 651.
    I have a piece that I wrote on with red, blue, black and green a couple of weeks ago.
    It leaves a ghost image if you just wipe with your finger, but still wipes off clean with a damp paper towel. Red is definitely the most difficult to wipe off.
    We'll see after another couple of weeks if it's still wiping off clean.
    Thanks for the Fellers tip. They just opened a new store in my area, may have to give them a call.
  8. gnatt66
    gnatt66 Active Member
    703
    Oct 31, 2007
    NH
    ive found that gloss laminate works in a pinch as long as only black markers are used.
  9. J Hill Designs
    J Hill Designs Major Contributor
    15,549
    16
    Hexis has a dry-erase vinyl that works really well
  10. signs2trade
    signs2trade Active Member
    Secret dry erase material
    A little secret.......Home Depot sales 4x8 sheets of ....I think its call Melamac....not sure....but its used in bathrooms....it is a perfect dry erase material. Its cheap. So if you need a solid sign for dry erase try it.
  11. Steve Werner
    Steve Werner Member
    108
    Both Hexis and General Formulations offer a very nice product. Hexis is their DW line, two different film thickness and 7 different widths. General Formulations is the Concept 111, three different widths.
  12. synergy_jim
    synergy_jim Very Active Member
    we also sell dry erase panels cut to custom shapes. PM or e-mail me for a quote....
    These are not laminated w/ film, but are painted w/ special dry erase paint and baked from the factory.
  13. J Hill Designs
    15,549
    16
    porcelain coated steel?
  14. Mal
    Mal Member
    104
    17
    18
    May 11, 2008
    Eastern Ontario
    Everything I've tried, including two part epoxy specialty dry erase paint, fails in outdoor applications. The UV just seems to cure the ink into the surface, especially red. I don't do them anymore.
  15. cptcorn
    cptcorn adad
    1,210
    2
    36
    Jul 16, 2007
    Two Harbors
    These are being cut and placed on custom cut out wood pieces for a national customer. I heard a rumor from my supplier about 651 working, figured you guys would know... Every time I've cut these its been a pain in the ***.
    These pieces are 5"x14".
  16. ddubia
    ddubia Member
    361
    1
    16
    Sep 13, 2006
    Northeast Ohio
    "A little secret.......Home Depot sales 4x8 sheets of ....I think its call Melamac...."
    You may be thinking of Masonite. That's what we use in our shop for a dry erase board. It's been working for over 3 years. It's really inexpensive. We got ours white one-side an put graph lines on it using vinyl.
    I think Melamac is the stuff they make durable dinnerware out of. ??
    Geesh, I just noticed the OP was from back in '09.
    (guess I was bored and just surfing around the site looking for something interesting.)
  17. GVP
    GVP Active Member
    829
    19
    18
    Nov 11, 2005
    Swift Current, SK
    "I think its call Melamac...."
    Isn't that the planet Alf comes from? :Big Laugh
  18. G-Artist
    G-Artist Active Member
    526
    Thinking of Melamine?
    That is used for whiteboards plus it has a good fire resistance rating, should that be important.
