Oracal 751
Discussion in 'Gerber' started by peewee the pinstriper, Jul 21, 2010.
  1. peewee the pinstriper
    peewee the pinstriper Member
    143
    Not wanting to mix up topics even though they are related. When I print in Oracal 751 (651 never is a problem) I always get fish eyes in my prints. What cast DO YOU recommend and have had good luck with?
  2. J Hill Designs
    J Hill Designs Major Contributor
    15,549
    17
    scotchcal
  3. thmooch
    thmooch Active Member
    556
    Mar 13, 2007
    sc
    Suggest Gerber Vinyl. Have you tried cleaning the 751 with alcohol prior to printing?
  4. Obsdian
    Obsdian New Member
    3
    I've always used Avery and never had a problem, with solvent & latex ink
  5. Fred Weiss
    Fred Weiss Merchant Member
    20,567
    423
    83
    Sep 11, 2003
    Olympia, WA
    We ran Oracal 751 for several years and finally threw in the towel on it after they made some unannounced changes that effected thermal printing on it. What we found was that black foils in particular would not print correctly on the 751 while other colors would. Yyet the same black foils would print just fine on other colors of 751. We phased them out and returned to Gerber/3M 220 Scotchcal and have not had any problems with that choice.
  6. WhiskeyDreamer
    WhiskeyDreamer Professional Snow Ninja
    3,555
    81
    48
    Aug 6, 2007
    Riften
    i print on 751 all the time with no issues....what foils are you guys using??
  7. Fred Weiss
    20,567
    423
    83
    Sep 11, 2003
    Olympia, WA
    I use mostly Apex/Duracoat with a full stock of GSP foils on the shelf when needed.
  8. peewee the pinstriper
    143
    Same as Fred , Duracoat, Apex, Gerber foils
  9. WhiskeyDreamer
    3,555
    81
    48
    Aug 6, 2007
    Riften
    i only print gerber foils (especially for a cast material)....i reserve the 09 and colorset foils for temp signs like golf tourneys and such....maybe that's the difference.... when you're talking about this print problem....are you printing gerber or other foils on the 751??
  10. Fred Weiss
    20,567
    423
    83
    Sep 11, 2003
    Olympia, WA
    In our case you need to realize that we had been using 751 for at least two years when we started having problems. We were able to substitute Gerber's spot black to finish the job but were troubled by the change. We wondered if other 751 prints might fail prematurely even though they appeared fine when coming off the printer.
    Our experience with Duracoat foils has been excellent and all indications are that Duracoat is equal to or superior to Gerber's foil line at less than half the price. Our choice seemed obvious since we use a lot more footage of foil than vinyl. We opted to stay with the foil and upgrade our vinyl to the proven Gerber/3M vinyl.
