Suggestions Orafol 3651RA for Wall Wraps
Mattie_BR
Hello everyone,
Does anyone use Orafol 3651RA for wall wraps? I understand it has a permanent solvent adhesive, but it seems a good option for walls painted with zero VOC paint.
Any review on how was the install will be appreciated.
Thanks!
CanuckSigns
It will work for a permanent installation, just make sure the client is aware that the wall will require extreme repair work if the vinyl is ever removed.
RPM
If your doing a wall wrap, you don't need RA. Plus you should do a wall test before you print to test it will stick. We have a 3M wall test kit. We will always test with different vinyl samples and gauges to ensure best results before we produce anything. Just to cover your butt......
