OUCHY OUCHY OUUUUUU..... thankfor good drugs))))
OldPaint
my right arm.............carpel tunnel & alna surgery monday((((((
You need some hooch or some reasonable fact simile.
Guarisci presto. :wink:
OldPaint
the little finger, ring finger & middle finger had lost any grip. thats what the alna surgery is supposed to help.
See, your mama told you not to do it or you'd go blind. Well, you wear glasses and evidently your grip was far too tight. Cut off the circulation to the bottom end of your hand. Ei,ei,ei.......... Can you do anything with your left hand ?? Are you at all ambidextrous ??
John Butto
Looks like Old Paint can use his left hand to type. You won't be driving that GTO with the Hurst shifter for awhile. Hope you heal fast.
Bly
I bet it's from typing all those brackets all the time.
Gino better watch out. Full stops can get ya too.
fixtureman
My daughter in law had it done with minimum invasive surgery only had a small incision. and was able to use her hand pretty quick. My daughter had her's done t the same the same time but had the normal operation and hers took a long time before she could use it.
DizzyMarkus
yikes good luck with the surgery --- have them trim those nails while your in there hehehe J/K Mr :Big Laugh
Markus
John Butto
Old Paint plays flamenco guitar at a Mexican flop house right outside of Pensacola Navy base at night. Thus the reason for the long fingernails and the carpel tunnel.
CP Signs
Hang in there. Gets better. Had both hands done. Waited way to long. Because of medical problems, I couldn't take pain killers. But it's al worth it.
