Output not what expected
Discussion in 'Flexi' started by weeding4life, May 15, 2005.
  1. weeding4life
    weeding4life New Member
    5
    I am using a program call VE LXI Expert which I was led to beleive is the same as Flexi Pro. This is why I am posting this quetion here.
    Anyway a customer sent me a eps file with what he wants cut. I load it into the program and cut it but the results are totally not what I was expecting. It cuts the graphics pretty good but it then proceeds to cut a line up and down over the whole graphic. It is hard to explain but it basically will go up and down over the whole graphic and cut a line. I never seen this before and need some help with this.
  2. Fred Weiss
    Fred Weiss Merchant Member
    20,919
    544
    113
    Sep 11, 2003
    Olympia, WA
    Do you see any extra cut lines with the preview off?
    Send me the original EPS file and i can probably figure out what's going on.
    My Email
  3. dynawg
    dynawg Member
    101
    Have you looked at it in wireframe to see if there is a path up through the graphic? I've been surprised by cuts I didn't expect only find a path or object I didn't expect when I went to wireframe.
  4. Scott Reynolds
    Scott Reynolds Active Member
    828
    Sounds like there is a white fill.... I would ask you to send me a copy of the file, but Freds on it........
    :thumb:
  5. WVB
    WVB Very Active Member
    2,749
    LXi is made by Flexi for Signwarehouse. Are you using a lynx plotter? I have heard issues were the plotter itself will drag the knife across the image and create that line only to destroy the graphic. Also change into wireframe mode and see if there are any stray lines etc.
  6. Mike Paul
    Mike Paul Major Contributor
    5,438
    8
    38
    Dec 30, 2003
    NJ
    Check your material size in P. Mgr.
    Sounds like your "material length" is not set properly.
  7. Kevin Huffman
    Kevin Huffman Member
    36
    Hey Weeding4life,
    Is that image a lot of different colors? Or is it just a single color?
    If it is a single color you can cut it with ease. When you go to your cut/plot screen, go to the advance tab, uncheck where it says send all colors. Go to back to the general tab you will a couple of box in the upper right and corner with different colors. Just click the color that your image is, it should show you the image. Then send just that color to the cutter.
    If the image is a lot of different colors I would have to see the image to be able to tell you what is wrong with it.
  8. PMG
    PMG Very Active Member
    2,453
    I have the same problem,,the problem is when i first put the blade in,,make sure its set in all the way,when i pay attenion to how the blade is set in,,i have not had this problem sence!
  9. PMG
    2,453
    Sorry,read the post wrong,i get that problem doin eps files,when its faded 2 color,you need to make it all one color ,or cut the seperate colors and place them to make multi color fade!
  10. Fred Weiss
    20,919
    544
    113
    Sep 11, 2003
    Olympia, WA
    I guess he must have figured it out for himself. :Sleeping:
