Outside Sign Frames for Overhead
CES020
I'm looking for a supplier for a simple frame. I know I can find a shop and have one cut and welded, but I'm hoping to find someone that sells them for a living so I don't have to find a shop and go through all that, then getting it painted, etc.
I'm talking about a simple, 2" or 3" square tubing (haven't measured the one I trying to match yet), aluminum with an inside dimension of about 72" x 24". With the usual mounting tabs welded on the inside, towards the back, and the sign insert resting in a lip that's created with angle welded into place on the inside of the frame. The panel is just an aluminum panel that will install into the frame.
Very common in small industrial parks. Usually that dark brown/bronze color.
Anyone know a source?
Thanks-
Steve
