Overlap and Cutting Out- Please Help
Discussion in 'Newbie Forum' started by Speedsterbeast, May 10, 2010.
  1. Speedsterbeast
    Speedsterbeast Active Member
    799
    4
    18
    Feb 1, 2010
    Thunder Bay
    I am looking for help on how to overlap an image and cut out the back layer using the lines of the front layer (I hope that is clear) I did some searching and found an older post called overlaps and cutouts. This what I am referring to. I am using Sign Warehouse LXI Master Plus 8.5. I played around with the layering tools, but could not figure it out. I would like to know what tool(s) help me with this.
    Please know that I try to solve challenges myself, and do a search on old posts before asking. I am stuck.
    Cheers.
  2. Mosh
    Mosh Major Contributor
    5,809
    41
    48
    Oct 19, 2009
    Nerbaska
    Do you mean outlines? We use LignLab, this is done prety simply in there if this is what you are trying.
  3. Marlene
    Marlene Major Contributor
    10,970
    264
    83
    Jun 8, 2004
    Vermont
    a clipping path? it kind of sounds like that might be what you are trying to do. go to www.bing.com type in clipping path and then select images. there are some samples of clipping paths there. see if that is what you are trying to do. once we figure out if it is or not, we might be able to help.
  4. TresL
    TresL Very Active Member
    1,010
    Oct 24, 2005
    perf cutting?
  5. J Hill Designs
    J Hill Designs Major Contributor
    15,549
    17
    choke/spread?
