Overspray?
Gasper
So i have this weird problem with my Mutoh rockhopper 46 and flexi 8.6..
If import a pdf for example in flexisign and i plot from there i get some weird overspray, black.. if i put a file directly into production manager it prints ok, no overspray.. tho it seems as, when it loads/prints from flexisign to production manager everything, colors, are thicker.. as its using a profile.. but im usually not using one. Just using the microdot option..
Its not static, im sure.. ive grounded the printer to a radiator just in case it was static.. i tried changing temperature 40, 45, 50 degrees celsius.. no change.. would anyone have an idea whats happening. And yes each time ive printwd from flexisign i used the production manager settings.. so all should be the same. Im a bit lost. I know its an old printer.. but it works fine for the stuff that i need
Ive attached some images..
