Oxygen hydrogen acrylic polishing machine
montrealsigns
Hello has anyone here used a Oxygen hydrogen acrylic polishing machine?do they work well? Any recommendations? Where do I purchase one?
Thank you
James Burke
That combination sounds interestingly dangerous...
Google the word and you'll get a bunch of sources.
JB
asd
why? why re invent the wheel, i polished acrylic letters before with a simple torch and a small 1lb. propane tank that you get a at any hardware store.
Superior_Adam
We have the Hydrogen/Oxygen Combo. Go to your local welding store that sells bottles and they can get you set up with everything your need. The torch is the same as you would use with a Acetylene set up but there is a different pressure gauge that is for Hydrogen. Yes we used to use propane but you will get small black spots from time to time. The hydrogen/oxygen is a cleaner burn and we get much better results after we switched.
