So when I'm cutting a large decal (single color die-cut style) into smaller sections I adjust the panel size to a size that will fit my material and cut each panel as separate jobs.  But in doing so the straight line it makes seems to get cut twice on the first panel I make.  Then I think it gets cut 3 times on the second panel since that straight line always cuts completely through the paper on the second job.  Any settings I can change to fix this other than going back and manually cutting into sections?  I think "easy weed" causes one of the extra cuts but still doesn't explain where this third one is coming from on the second panel.
