Pantone color matching module
JR's
Hi guys,
I am running signlab print and cut version 9.1 revision 1.
I am looking for the Pantone color matching module. Do you know if it's in this version of sign lab?
Thanks in advance.
yes, in the bottom corner near the color color palette you need to click the button in the corner were you can add/load to your palette.....a list comes up......click the find/locate PMS color then the option will come up to selected coated/uncoated etc.... then you can select the PMS color.
Vinyldog
Vinyl Pro 8.0 VW Edition Palette question
I’ve been using the Roland Color System Library Palette for designs I print to VersaWorks but now I’m printing to the HP L310 so what might be a better Palette choice?
I’m hoping going to another Palette might also remedy another situation.
Currently, when I choose PR11K, a dark green, it displays on the screen as a bright neon green. Very confusing for the customer.
