Partition in XP
PMG
I was told i can partition my hard drives within XP,and not a Partition program,where do i go about doing this within XP? I want to split one of my drives up for just for the scratch disk for Adobe Illustrator,and Photoshop!! Thanks
PMG
I looked in there the only thing that is active when i Rclick on the drive is-Open-Explore-Change Drive letter or Path-Properties and Help,the help file tells ya how to do it,but what it says is not what i see,and yes im logged in as Admim..........
Ken
Or, you could always Format:C...kidding..don't do that.
Partition Magic is good.
Ken
Shovelhead
if space wasn't allocated.......
when your drive was formatted..........I don't believe you can partition
after the fact without formatting the drive.
mark in tx
Adding a second drive just for the swap disk can be a good idea. I heartily recommend partition magic, or if you feel adventurous, a Knoppix live disk can do the job if you want to experiment with Linux.
Make sure that the partition or the second drive that you assign as your swap is not shared, or networked. That will increase the performance as a swap.
Lastly, add as much RAM as you can.
I went from 2 gigs of ram to 4 gigs, and I noticed an immediate speed up.
PMG
I do have 2....1 internal and 1 external,and was thinking i need to split the internal 250 up for the scratch disk,the reason i say this is so the data being transfered wont be lost or even slower if i split the external drive,i have it running on the external now ,and it still seems to hang up now and then and act stupid...or is this the norm for adobe products!!!
