Pc-60
Discussion in 'Roland' started by jbennett, Mar 21, 2007.
  1. jbennett
    jbennett Member
    350
    Jun 12, 2003
    Tennessee
    Does anyone own a PC-60? What are the largest single print images that it is capable of? Is it best for smaller decal type stuff? Also, what is the average /sq ft. print price? All help is appreciated.
    jbennett
  2. High Octane
    High Octane Active Member
    923
    13
    18
    Mar 27, 2005
    Fenton, Michigan
    Just Say No!
  3. jbennett
    jbennett Member
    350
    Jun 12, 2003
    Tennessee
    Does that mean stay away from a pc-60?
  4. High Octane
    923
    13
    18
    Mar 27, 2005
    Fenton, Michigan
    Sure does
  5. weaselboogie
    weaselboogie Very Active Member
    3,835
    9
    38
    Apr 23, 2006
    Us
    Yes. Good for cutting vinyl and small occasional print work, and I stress small and occasional. Expensive to print. The good part is that it's resin based so you can get 5 years without fade. The 60 as opposed to the 600 uses more ribbon (yes ribbon). If you are just printing 1 - 4" decal, the ribbon will run the entire 24", not printing, just wasting. the print head scratch very easily because they are in direct contact with the vinyl. Any dirt and you're replacing it. We used to clean the vinyl before we printed even if it was fresh off the roll and still had to replace the head 3 times! For some reason I was thinking it was costing US $10+ per sq ft to print , our cost.
  6. jbennett
    jbennett Member
    350
    Jun 12, 2003
    Tennessee
    WOW, thanks weasel for the specifics. I am out on it and will just keep saving for a 30" versacamm. I was trying to figure out if it would even be a good way to get into printing in the interim, but think it would just be money wasted.
    jbennett
  7. High Octane
    923
    13
    18
    Mar 27, 2005
    Fenton, Michigan
    Versacamm! Now yer talkin'!
  8. Jackpine
    Jackpine Major Contributor
    See if you can find a PC 600. They are a newer model and have a ribbon saving feature.
    I printed 90% in RGB CMY mode and you would need a magnifying glass to see the difference. It saved 25% orf the ribbon cost. You can print on intermediate gloss white vinyl. I used ShineRite from Fellers, but 651 or 751 would do fine. Keep the dust away and clean the print head when it is hot and it will last.
