PDF file help
Discussion in 'Adobe' started by B Snyder, May 16, 2007.
  1. B Snyder
    B Snyder Very Active Member
    1,433
    Is there a way to open a PDF file in Adobe Acrobat Pro (I have version 8) and re-save it with the text converted from fonts to outlines/paths/curves so that it can easily be imported into a vector graphics program? If not, is there another program that can do this?
  2. Replicator
    Replicator Major Contributor
    10,230
    9
    38
    Nov 19, 2006
    Sun City, AZ
    Why wouldn't you be able to open a PDF file in Adobe Acrobat Pro :help:
  3. Pro Signs & Graphix
    Pro Signs & Graphix Very Active Member
    2,477
    If you are asking if you could take PDF with a rasterized image and turn that into a vector image - no.
  4. vid
    vid Very Active Member
    1,442
    3
    38
    Jun 11, 2003
    California
    The Vector Doctor posted a tip for converting type to outlines in a PDF using Illustrator here.
    It's one of my top five "Signs101 Tips and Tricks" - the Vector Doctor rocks for that one!
  5. B Snyder
    1,433
    My question was:
    and
    re-save it
    with the text converted from fonts to outlines/paths/curves.
    I know I can open the file in Acrobat Pro and I'm not asking anything about raster images.
    Thanks Vid! I'll try this now. Seems like it would work.
  6. TresL
    TresL Very Active Member
    1,010
    Oct 24, 2005
    Acrobat won't convert the fonts to outlines.
    ILL or other vector program will.
    I use ILL to convert to outlines & then save to a PDF and edit in Acrobat.
    (helps save on PDF file size when creating forms)
  7. thewood
    thewood Very Active Member
    1,781
    Dec 28, 2005
    Tennessee
    Great link, Vid. That's gonna come in handy.
  8. B Snyder
    1,433
    Thanks TresL. The problem with this file is that the fonts are embedded and I don't have them on my system. So, when I try to bring the PDF into AI or CDR I'm asked for substitutes.
  9. signage
    signage Major Contributor
    9,314
    41
    48
    Oct 5, 2005
    Penn
    Contact the client and have them convert the fonts to curves and resend it to you or tell them they will have to purchase the fonts for you,
  10. B Snyder
    1,433
    Thanks for your advice on how to handle my client but the question I asked doesn't involve a client. :)
  11. Is the Vector Doctor the Man or what........:U Rock:
  12. Rodan68
    Rodan68 Member
    93
    Mar 6, 2007
    Bay Area
    You can save the file as an eps file with the option convert fonts to outlines. This works most of the times. Make sure the eps looks like the original pdf before doing anything because sometimes the eps loses the transparencies, gradients, color space, etc.
  13. B Snyder
    1,433
    I don't have this option in Acrobat Pro v8. Are you referring to another program?
  14. Rodan68
    Rodan68 Member
    93
    Mar 6, 2007
    Bay Area
    I don't know about version 8 but in version 7 Professional you can go to File,Save As, File Type eps and alter the settings. That's strange that version 8 wouldn't have this option.
  15. B Snyder
    1,433
    Just finished using the vector doctor's method and it works perfectly! Thanks!
    Rodan68 - No, I don't see an option to convert fonts to outlines in Acrobat Pro v8.
  16. The Vector Doctor
    The Vector Doctor Very Active Member
    3,457
    140
    63
    Aug 15, 2005
    Ohio
    Glad to help. I have a few other tricks that I need to take the time to share.
  17. creative
    creative Member
    225
    Try opening the file with Photoshop, rasterize the file then you can save as an .eps, .jpg, .psd, open in corel, trace the file and you'll have the vector objects.
    there might be easier ways but this one work in most, not all situations.
  18. Bobby H
    Bobby H Very Active Member
    1,847
    100
    63
    Feb 4, 2005
    Lawton, OK
    Nah. To heck with opening the PDF in Photoshop and auto tracing.
    The very best method to use is the one The Vector Doctor described. Placing the PDF and using the flatten transparency command/dialog in Adobe Illustrator yields perfect results.
    Of course...you do need to own a recent version of Adobe Illustrator for the trick to work. CorelDRAW doesn't have a comparable feature and is pretty limited overall in how it can open/place PDFs.
  19. Bobby H
    1,847
    100
    63
    Feb 4, 2005
    Lawton, OK
    I forgot to add an important note.
    The trick used to convert embedded fonts to outlines can also work on Illustrator files as well, but with an exception. The Illustrator files must be saved with PDF compatibility turned on. Something saved down to an early "legacy" version or saved from CS2 with the PDF feature unchecked will not work.
