WildWestDesigns said:Yet again, I do know the difference between "opening" and "placing" and every single time it switches the font. It doesn't give the messages as y'all point out. BUT it does still switch them. It does still do the substitution.
The procedure I have used has worked reliably every time. I've never run into a problem with it on dozens upon dozens of different PDFs over the years. If I got a font substitution problem it's only because I had a brain fart and forgot to do something, like clicking the "link" option in the place dialog box.
Can you post a copy of this particular PDF that is substituting fonts to no avail? Or post a link to it? What you are describing is not common at all. I need to see one of these problem PDFs to see what it is you're describing.
To repeat what I said earlier about font restrictions: very often if a font has restrictions it will not allow itself to be embedded into a PDF at all. You won't see the correct font when the PDF is viewed in Acrobat Reader unless the font is installed on the computer viewing it. Every single time I've seen a PDF with a particular font embedded I have been able to convert it to outlines in Adobe Illustrator. That even goes for Mac system fonts embedded in a PDF and converted using a Windows version of Illustrator. I've done it. I've even converted iOS system fonts from my iPad Pro using PDFs saved from Autodesk Graphic.
WildWestDesigns said:Converting to curves/outlines makes all those possible issues moot. What I don't get, is why people would still suggest a method that has the potential for complication(s) versus a method that doesn't. I don't know of one exception to fonts converted to outlines/curves to which it would throw an error itself, at least in my experience.
There are multiple reasons why I suggest using flatten transparency method.
Very often the client calling us for the sign work is not the person who created the PDF artwork with active, embedded fonts. If it is someone working for a larger company that means the creator will be in some other city/town and not very easy to contact. Converting the embedded fonts in a client supplied PDF is a whole lot faster than making the client spend hours or days trying to find someone who has the original art file and getting that person to save another copy with the fonts converted. Clients do not like messing with those kinds of hassles. Sometimes they're stuck doing that when they supply a crummy JPEG web page image as the "logo." If you're able to reduce a customer's headaches you come out farther ahead.
Then there's the issue of getting legit artwork of major brands. To repeat what I said earlier: Brands of the World sucks.. The site is infected with all sorts of counterfeit, fanboy drawn re-creations of logos rather than the real things. The site has conflicting standards on what gets uploaded. Sometimes a logo will be legit, sometimes not. In the end it's still a crap shoot due to an overall lack of credibility there. So if I have to hit the ground running on a project using a major brand I'll go hunt for PDFs at that company's site rather than visit Brands of the World.
