.pdf to Coral File
Discussion in 'Clipart, Vehicle Templates and Digital Files' started by Accelerated Graphics, Jul 19, 2007.
  1. Accelerated Graphics
    Accelerated Graphics Active Member
    889
    1
    18
    Jan 11, 2005
    Burleson
    I have a .pdf that I'm trying to convert to a Corel or eps fle that I can print anyone have anyway to do this.. I tryed in X3 and it said the file is corrupt.
  2. Craig Sjoquist
    Craig Sjoquist Major Contributor
    6,746
    4
    38
    Jun 18, 2004
    Orlando
    if I got this right .... go to save as >you see lots of options convert to pdf, or media then a window opens up ya got more choices ... do not remember all of it but it explains I've not done enough image moving yet but X3 is fairly easy .. also ya got help note to look at
    13 folds
  3. Accelerated Graphics
    889
    1
    18
    Jan 11, 2005
    Burleson
    I'm trying to open a .pdf in X3 ...
  4. rcook99
    rcook99 Very Active Member
    2,139
    3
    38
    May 25, 2006
    NE
    Rick, If you are trying to open the file you have to import it into X3 and open it as curves then you can resave it into corel as a .cdr file. Hope this helps.
  5. Replicator
    Replicator Major Contributor
    10,230
    9
    38
    Nov 19, 2006
    Sun City, AZ
    Can you open the pdf with a pdf reader ?
  6. Justin (Inactive)
    Justin (Inactive) Member
    48
    Rcook99's advice should be just the ticket. I'm still using Corel 11, but it should work the same, just import it instead of trying to open.
    Justin
  7. Jackpine
    Jackpine Major Contributor
    I have copy and paste into CorelX3 if it didn't import, but usually import.
  8. Bobby H
    Bobby H Very Active Member
    2,182
    187
    63
    Feb 4, 2005
    Lawton, OK
    If you have to deal with PDFs frequently, Adobe Illustrator would be an excellent investment.
    I've had lots of grief trying to import PDFs directly into CorelDRAW and Flexi. I always get much better results when being able to open the PDF in Illustrator, do work on the file in there (like getting rid of various clipping masks, expanding strokes, etc.) and ending up with artwork that can actually be sent to a vinyl plotter or computerized routing table.
